Why there is no setting for dwg translator setup in ac 15?
Why there is no setting for dwg translator setup in archicad 15 like 14 to make it in meters and make colors table when converting to autocad??
6 Replies 6
Stress Co_
Ahmed: I know this doesn't help you, but just to confirm....
I see it (mac version). Will stretching the window make it magically appear??
Marc Corney, Architect
Red Canoe Architecture, P. A.
No problem here, either, Ahmed. Like Mark, I'm on a Mac though...
Are you running build 3006 of 15, or are you using 3003 (what is on the installation DVD)? If on 3003, update to 3006.
What happens if you access the translators from the File menu as shown in the attached screenshot? Does the panel appear to let you customize the (unlocked) settings?
Does Mark's stretch-the-dialog-taller idea help?
If you take a standard setting and duplicate it, can you edit then?
Karl
I am on Windows with AC15 INT and I have it.
I don't know what to say, maybe you should tr reinstalling AC15.
thanks i do click on below double noting there is no arrow indicate but it works and i have settings now
Resolved.
But I found another trouble. There is no "merge to a one dwg file" option.
Please help me
Pragmus wrote:
Resolved.
Please help me
Pragmus,
That option should appear when you choose a folder with layouts in - not views.
