2008-08-1512:43 PM - last edited on 2023-05-2505:34 PM by Rubia Torres
Window opened in the middle of 2 story building?
2008-08-1512:43 PM
I have a window which open above the landing 1 meter in the stair well, so how to show this window at the plan, either GF or FF? It shows on both of the floor plans. How can I do for this window to show on the FF only?
You will want to use the Floor Plan Cut Plane, which is set for each View. The wall containing the window will need to be set to something other than Symbolic Cut. The Floor Plan Cut Plane is a bit complex, you should read the Help files to understand its features.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro OSX14 | 36 gb ram
