Window opened in the middle of 2 story building?
I have a window which open above the landing 1 meter in the stair well, so how to show this window at the plan, either GF or FF? It shows on both of the floor plans. How can I do for this window to show on the FF only?
eric
David Maudlin
eric:
You will want to use the Floor Plan Cut Plane, which is set for each View. The wall containing the window will need to be set to something other than Symbolic Cut. The Floor Plan Cut Plane is a bit complex, you should read the Help files to understand its features.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
