Wooden Stairs
toman311
I'm trying to get wood stairs to look right, but I cannot seem to be able to figure it out.
I would like the stringers to be cut to the treads and have no risers. Also, the treads need to overhang the edge of the outside stringers.
I attached an image of what I want, except that, in the image, the treads don't overhang the stringers. The stairs in the attachment were created before the newly redesigned stair tool, which is why I am confused on how to do this.
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
1 REPLY 1
Yeah, they moved some of the stuff around and it is a little less intuitive as before but still possible.
You will need to change your flight structure to "Beam", then use the "Wedge" in the secondary support section. Takes a couple minutes to get it looking right but it should be pretty quick.
