2009-10-22 05:50 PM - last edited on 2023-05-23 04:52 PM by Rubia Torres
2009-10-22 08:44 PM
2009-10-22 09:31 PM
Master wrote:This may be a bit off topic but I wanted to comment that I have had trouble defining parameter settings with Zone Categories and having the actual zones repeat them after I put them in. It seems like the only setting the zone tool repeats is the zone category name and color, that's it. Did I miss a step or is this a bug/issue with ArchiCAD?
This you can set in the Options/Element Attributes/Zone categories. For each new category you can set different settings.
2009-10-23 12:58 AM
ksymons19 wrote:I'm not sure I understand? Where and how are you 'defining parameter settings' at the moment? Post a screenshot perhaps? Are you selecting the zone on plan, then opening it's settings dialog box to make changes?
2009-10-23 03:33 PM
2009-10-23 08:13 PM
