Bruce
Zone outline
What's the trick to getting the zone outline to display? I've turned on the outline button as described in the online help, but it won't show or print.
It will show if the selection is hilited, but once it's deselected...nada.
Any ideas?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
5 Replies 5
Aussie John
check your display settings
Cheers John
[/size]
In AC10 that's Document > Model View Options
Aussie John
Thanks Matthew - I should of been more detailed
Cheers John
[/size]
Rod Jurich
More to the point John, GS shouldn't have changed things that were known, that were simple to understand in the begining.
I'm still having to check myself when talking about such things.
And insult to injury they hide them deeper in the menu structure.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
I can understand why they did it (the options keep expanding and it was appropriate to separate the screen display options from those that affect output), but the implementation leaves a bit to be desired. The menu item "Model View Options" doesn't exactly scream "these set your up your views for printed output."
Perhaps the simplest solution would be to call them "Display Options" and "View Options". The meanings still aren't definitive but they would be easier to get accustomed to.
