Gianito
Zone stamp GS ITA - Timbro Zona GS ITA
Hi, I have loaded the Archiclub library on Archicad, however I cannot see the GS ITA zone stamp in the zone menu. Can you tell me why?
1 Reply 1
The zone stamp is an object and it needs to be in one of your loaded libraries before you can use it - as it seems you may have done already.
Then you need to go to Options menu > Element Attributes > Zone Categories to set up the zone stamp for use in a zone category.
You then choose the zone category as you place a zone and it will use the stamp you have chosen.
If you have followed those steps it should be working for you.
