SOLVED!
Zone stamp showing on plan but not showing on layout
Paolo Pi
Hi. I have a problem with the zone stamps.
As the title says, I can see the zone stamps in my plans, but when I add the plan drawing to my layout the stamps are not visible.
I tried to open the source directly from the drawing to double-check, and everything looked correct.
This problem occurs only on some layouts, not all of them. I also tried to copy one drawing where the stamps were visible and relink the drawing to the plan I needed, and the stamps disappeared again.
I checked the zone settings, renovation filters, MVO.. everything seems fine but maybe I am missing some settings.
Any ideas?
Thanks in advance
Operating system used: Windows 10
AC25 (since AC19), windows 11
Intel Core Ultra 9 185H 2.30 GHz 64.0 GB
1 ACCEPTED SOLUTION
Solution
Paolo Pi
Update:
I just found the solution. I will post it anyway in case it might be useful for other people.
It was very easy actually: The MVO saved in the view settings was missing. Probably someone in the team deleted it and never replaced it in the view settings.
Then probably the software picked the first MVO in the list which was one with the "show zone stamp" option unchecked.
1 REPLY 1
Solution
Paolo Pi
Update:
Setup info provided by author
