Zone units
Hi, I have an issue with this zone command: Its in m2, and I need them in sf, i changed it in OPTIONS>WORK PREFERENCES>CALCULATION UNITS and change it to sf, but still does not change when I apply the zone tool, am I doing something wrong?
2 REPLIES 2
The setting that governs this is in Options > Project Preferences > Dimensions (see attached).
Depending on the zone stamp you are using you may also need to update any existing zones to recalculate with the new settings (gross area is automatic - net requires update).
edit: Oops, here is the attachment...
Djordje
No attachment
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
