Zones in not shown in details
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-05-14 09:27 PM
Problem is when we use the detail tool we lose the Zone. Is there a setting I am missing somewhere?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-17 12:57 AM
Joseph wrote:The detail and worksheets tools in AC11 have a 'Copy Construction Elements Only' checkbox. Checking it will show the following in the resulting detail or worksheet window (these lists aren't necessarily complete!):
Is this still the case in AC11?
Thanks,
Joseph
Walls
Wall Ends
Columns (including crosshair)
Beams (including center line)
Windows
Doors
Library Parts
Lamps
Stairs
Slabs
Roofs
Meshes
Zones (
Fills (
Lines
Arcs/Circles
Polylines
Splines
Hotspots
Corner Windows
Unchecking will show the following in the resulting detail or worksheet window:
Walls
Wall Ends
Windows
Doors
Library Parts
Lamps
Stairs
Slabs
Roofs
Meshes
Dimensions
Radial Dimensions (including centerpoint)
Level Dimensions
Angle Dimensions
Texts
Labels
Zones (including stamps)
Fills (including area text)
Lines
Arcs/Circles
Polylines
Splines
Figures
Drawings
Hotspots
Sections (including limited depth range)
Details (including boundary)
Corner Windows
Skylights
Elevations (including limited depth range)
Interior Elevations
Worksheets (including boundary)
Not including Cameras or Interior Elevation limit lines.
Everything will still be 2D though, as these views aren't 'live'.
Using zoomed views directly from the floor plan keeps the enlarged floor plan live, but may mean you'll need additional layers for masking extraneous information. You wouldn't want these masking layers on in any other plan, afterall.
Creating a view using a worksheet (or detail) will give you more flexibility because it is derived from a separate worksheet/detail window. This means that extraneous information can be removed using the same layers as in the floor plan. But then the view isn't 'live' - you can rebuild from the source view, but it's not automatic.
So IMHO it comes down to keeping the views automatically live vs. possibly requiring extra layers.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-17 01:19 AM
Link wrote:Thanks Link,
.....Creating a view using a worksheet (or detail) will give you more flexibility because it is derived from a separate worksheet/detail window. This means that extraneous information can be removed using the same layers as in the floor plan. But then the view isn't 'live' - you can rebuild from the source view, but it's not automatic.
Link.
Do the added annotations and clean ups go away after rebuilding?
Thanks,
Joseph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-17 01:27 AM
Keep in mind this is limited to the following tools:
Library Parts
Dimensions
Radial Dimensions
Level Dimensions
Angle Dimensions
Texts
Labels
Fills
Lines
Arcs/Circles
Polylines
Splines
Figures
Drawings
Hotspots
Sections
Details (!)
Elevations
Worksheets (!)
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-17 04:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 12:22 AM
Melisa wrote:
........provide a place for people to draft 2D linework, then that is referenced into the plan window via the virtual trace........
You are saying it can be referenced to 3D window ALSO to aid in refining the 3D model?
Joseph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 12:32 AM
Same thing for the detail window actually
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 12:49 AM
Joseph wrote:unfortunately not.
Joseph wrote:why indeed! the reality is pretty close to what melisa said: worksheets are a place to keep those aspects of the project information that aren't necessarily a part of the virtual building model and its closely associated views. but i have a feeling that both 'details'
So if WorkSheet tool is same as Detail Tool ... why do we need the Detail Tool?
~/archiben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 12:50 AM
Link wrote:So again, why not combine the Detail & Sketch Windows together?
......Same thing for the detail window actually![]()
Link.
Joseph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 12:54 AM
Hopefully GS will provide more direction there.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 12:55 AM
Joseph wrote:joseph - i think we double posted - see above (or below if that's how you're set up) for my reply.
interesting that you're calling the worksheet window the "sketch" window though . . !
~/archiben
