archistair 1.01 in ac9 error !!
I have a problem with archistair 1.01 in ac 9
for some odd reason it won't show up in my floorplan (or even in 3d view)
I have the archistair.lib loaded in the plugginmanager ac9 says the plug is installed correctly
I can open archistair ... fill in all the parameters ... but when I click ok .. nothing happens not even a dot for a unknown library part
Am i forgetting something ? or is it a bug ? any info is very much appreciated.
many thanx in advance
basdbas
my system
pc p4 3.0 ghz
1 gb ram
fx5200 128 ram
ac9
artlantis 4.5
1 REPLY 1
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
You simply didn't serialize it!
WHat you described is the common demo behaviour: you can browse the dialog windows but you can't insert/modify the stair objects...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
