cabinet end panel too deep
I've placed a cabinet and modified it's depth, the placed end panel didn't change size to match the cabinet. is there a way to do this?
wb
David Maudlin
wildernessbob:
Looks like a bug. The end panel(s) do not change size with the depth. This works for the Cabinet Base 1D, and I could not see the difference in the code with a quick look. A quick fix is to open the library part and add:
door_w=door_w
to the Call at line 219 in the 3D Script (this is the width of the end panel that for some reason is not getting passed to the macro for the end panel). If you are not familiar with GDL, then just report the bug to your local GS dealer and add the end panel some other way.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
