2007-06-2806:15 AM - last edited on 2023-05-2303:17 PM by Rubia Torres
2007-06-2806:15 AM
I am struggling with the A10 upgrade.
Previous versions would allow you to select elements...ie roofs or walls and get a quick calculation of the total sf area from the basic calculation pull-down menu.
Please help me understand how to simply do this in A10.
I have tried the Window/palletes/Element Info path and selected the "area on plan" button. It calculates each roof plane without showing an overall sf of all roofs selected. I guess you need to manually add each roof plane to get a total. This seems way to complicated.
AC10? i am not sure but try this.. at least its working in AC11 , select the element(s) , right click on schedule list in navigator " list floor plan selection only".. not sure in AC10
Rich, Just select all of the Roofs you want a calculation of and then select the Elements List / Basic shown in the attachment. It will give you the total.
Gerald Hoffman “The simplification of anything is always sensational” GKC Archicad 4.55 - 27-5030 USA 2019 MacBook Pro (64GB w/ AMD Radeon Pro 5600M GPU)
The Basic Element List will give you the area of the roof surface, not the 'Area on Plan', like the Element Information will. There's a difference, so be careful.
I am not sure if there are any 'Area on Plan' parameters available in List Schemes. So to answer your original question, no, not AFAIK.
