‎2012-08-13 09:31 PM
‎2012-08-13 09:58 PM
‎2012-08-13 10:53 PM
‎2012-08-13 11:54 PM
‎2012-08-19 09:00 PM
jballar wrote:
I hold the space bar down, then click to select the text. Or turn the on the Quick Select button. It looks like a magnet. You can select more than one text at a time using the shift button while you select the text.
After you have selected the text, then to edit the text, press the text button to activate the command. Click on the text again, and the text edit dialogue should pop up.
This also works with labels and dimensions.
Hope this helps.
Jeff
‎2012-12-12 11:04 AM
