check doubles add-on for archi 8.1 ??
Hi .. I have lot´s of double lines and objects. In Archicad 7.0 I use the check doubles add-on, but it doesn´t work in 8.0 and 8.1 versions. What we do in that cases ?
thanks
__archiben
mine is working fine . . .
make sure that you are using the correct 'check doubles' add-on from the archiCAD 8.1 goodies folder and not simply transferring your AC7 one across.
it needs to be loaded using the 'add-on manager...' tool in the 'tools' menu.
HTH
~/archiben
b e n _ f r o s t
