complex morph roof ???
hello,
Have created an inclined very shallow barrel vault roof which was a rectangle before clipping the corners with arc / circular curved elements in plan using the SEO tool. See screen shot below.
So far it looks great, but instead of having vertical edges created during the solid element operations, I need the edge to slope in 80 degrees from
the top surface of the roof edge all around the perimeter. This means the edge angle will vary from the vertical all around the roof.
Its edge should look like the overhang edge over the master bedroom
to the right of the screen shot.
Does anyone know of a good way to accomplish this brain twister.
Was just thinking maybe an inverted and very large cone section for each
curved corner might get me pretty close. Morph SEO a morph:-)
MrC
Hi Jonathan
slightly off topic..... but I was wondering where you got or how you made the rock objects in the foreground?
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
the part is called rots2
in a folder called NATUUR
in a folder called BIB pedros
You should be able to find searching one of those terms
MrC wrote:
Hi Jonathan
