copy, mirror and elevate
I have a unit site that I have built the first unit of and I need to copy, mirror and elevate each unit individually (they are all the same and are two storey).
The problem is, when I try to do this for multiple levels I can only do one storey at a time. I usually use the multiply option but that only seems to work on one level at a time. Is there a way to 'grab' all storeys and do them together?
10 Replies 10
Djordje
dobius wrote:
In my experience copy does work in 3d window but you first have to duplicate it (click a copy on the same spot) and the use the drag command. Copy doesn't work in section though.. too bad.
Just do Drag (Rotate, Mirror ...) a copy in 3D.
Drag (Rotate, Mirror ...) a copy, multiply, etc works in S/E for doors and windows. If you do other elements, it creates 2D views.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
