copy/paste in 3D window ?
gaba
I'm asking out of curiosity.
I have two open pln projects.
What is the technical problem that ArchiCAD doesn't allow you to routinely copy selected elements (Ctrl+C) from the 3D window of one project and paste them (Ctrl+V) into the 3D window of another project? After all, it could automatically paste them into the same 3D place, and the user could then move them, etc.
OK, I know you can copy from a 2D plan and paste into a 2D plan, etc.
Is it about the target story ? ArchiCAD can ask about that, etc.
But ArchiCAD also doesn't allow you to copy and paste elements into the 3D window using the clipboard, even in the same project. OK, you can drag and drop by holding the plus key, etc.
Operating system used: Windows 10
"When you seek knowledge, you will eventually find it. Then you will become its source - until such time as you must seek it again."
AC 7 - 27 (28), Twinmotion | Windows 10 Pro for Workstations
Dell 7740 Xeon | 64GB | RTX 3000 6GB + LG 2560x1080
Please add your vote to this 19 year old wish so that perhaps we can get this serious omission resolved at some point:
https://community.graphisoft.com/t5/Wishlist/Copy-and-Paste-in-3D/idi-p/37659
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
5 REPLIES 5
of course! I voted with pleasure!
it's a shame to ask for such basic functions of a 3D architectural design program in the 21st century
Hi all,
In addition to the a/m solution I can tell you that,
as Archicad is not an ordinary 3D modeling software as (AutoCAD, Sketchup or even Revit) and as it's a real BIM solution it won't handle elements as other applications do it, rather it handles the elements' information also to deliver them as expected.
So, try to save those selected elements as a module file, then placing them in the appropriate floor plan in the other file & break hotlink to embed the elements into this file.
See the attached screenshots showing the profiles before I transfer this complex profile column & after I placed as a module, I hope that helps.
AC 28 INT 3110/WIN 11
@Mahmoud Qenawi,I don't want to believe that BIM aspirations can be an obstacle to simple 3D copy/paste 😎
@Mahmoud Qenawi wrote:
Hi all,
There is nothing about BIM to prohibit copy/paste.  The clipboard (whether Windows or Mac) is a sophisticated data container ... and can contain almost anything with all of its meta data.  Hence there is, in principal, no need for modules/etc as the clipboard can contain all content necessary to implement the copy/paste.  To the extent that there may be some kind of data that cannot be held (I woud be surprised) - Graphisoft themselves merely needs to implement it as a hidden, temporary module file - totally transparent and behind the scenes to the user.
Setup info provided by author
