gabrielagg wrote:
Will this option work on Archicad START Edition?
I'm having the same issue, and already have checked all the options above.
Thanks!
This is a 9 year old post.
We now have Graphic Overrides rather than the MVO fill options.
You will need to use a rule that changes the fill to solid and the foreground pen to black - there is probably one there already (all fill solid), you may just need to tweak the pen colour.
Then set the criteria so it looks only for walls.
Create the Graphic Override that uses that rule.
Read up about Graphic Overrides and if you still have questions then post back.
