creating detail workflow on 2 different computers / files
hello,
we are currently working on a project where one person is developing the details using the detail tool and we would like for another person (different computer) to begin to organize the details on separate layouts and were wondering if there is a primitive workflow for bringing the finished details into the layouts?
at the moment, we would like to avoid using the teamwork method and are more interested in creating a simple workflow between the different files and different computers.
using Archicad version 11
any suggestions are greatly appreciated,
grodr
2 Replies 2
vfrontiers
Here's the good use for the OLD PMK's!...
Set up a PUBLISHER set to produce PMK's (I hope this was possible back in AC11)...
PLACE DRAWING... EXTERNAL.. navigate to PMK Folder you just created...
Now... I presume that you want the actual LAYOUTS as their own file... so just copy over your MASTER SHEET items.... create a matching subset in the "DETAIL" file and PLACE all the PMK's...
When changes are needed, you'll have to go back to the original file and RE-PUBLISH (can be done INDIVIDUALLY, if only a couple change)...
Let me know if this makes sense.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
You can just link the details from one file int the layouts of the other. This is easiest to do in the Organizer where you can have the views from the source file on the left and the layouts in the current file on the right.
