Here's the good use for the OLD PMK's!...
Set up a PUBLISHER set to produce PMK's (I hope this was possible back in AC11)...
PLACE DRAWING... EXTERNAL.. navigate to PMK Folder you just created...
Now... I presume that you want the actual LAYOUTS as their own file... so just copy over your MASTER SHEET items.... create a matching subset in the "DETAIL" file and PLACE all the PMK's...
When changes are needed, you'll have to go back to the original file and RE-PUBLISH (can be done INDIVIDUALLY, if only a couple change)...
Let me know if this makes sense.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
