curved roofs
Dear ArchiCAD team,
Can I define the roof pivot line as a curve instead of straighr.
Awaiting for your reply,
Thanks
Binoj
Dear Binoj,
No, You can not define the Pivot line of the roof tool different from a straight line. Nevertheless, you can use this trick:
-Define your pivot line with an auxiliary spline or arc segments. I'm supposing that by pivot line you mean the base of the roof.
-Use "snap points" and set it to either divisions or distance. this will be the length of the roof's pivot segments.
If you have a very weird shape on the roof, try with it first with the Mesh tool, and then create a roof form that mesh.
I hope this helps.
Cheers
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Dwight
In making a curved roof, it is best to NOT USE THE ROOF TOOL AT ALL.
The tool to make a curved roof is a combination of the wall tool with a complex profile.
See: Eric's article
Example attached.
Dwight Atkinson
