curvy slabs
Hello,
assume you have a 40 years old archive of about 500 hand made projects. As they are both valuable and profitable, you want to convert them into a digital archive. About 4/5 of the drawings consist of projections that can be calculated on the fly by a BIM CAD, so the problem reduces to importing the 2d plots. You take someone in your staff and ask him to do this accurately. He takes an old project, make a tiff image out of it, then read the image with the CAD and... now what? The person comes back to you with a pesky problem: the slabs are curvy, hand drawn, and the conversion turns out to be really difficult and less than accurate. You are not allowed to change the original shapes: the digital version must be an accurate 1:1 import of the original. I recollect the similar problem occurring in the 80', when the CAD could only draw straight lines and we had to give up with the very idea of using a CAD. Twenty+ years later, the situation has improved, so much that you can draw a curvy slab directly on the CAD, but the problem is still pending when importing old projects. There is indeed a difference between drawing directly in CAD and importing from an old project, and the 1:1 conversion is a must. The conversion of hundreds of project makes the case for a rapid method. Then my question is, how would you solve this problem with AC10?
22 Replies 22
Dwight
jdk wrote:
I understand that the main argument against proper vectorization is, that it would take work away from human professionals.
Bob
Who made THAT argument?
Dwight Atkinson
Dwight wrote:
Bob
Equus RIP
>For tracing freehand curves I use the spline tool. It is very easy to use with a minimum of control points. If your curves do not have a strict defining geometry then close enough probably is. You can then magic wand to the spline to approximate the curve with arcs for the model elements (they don't like splines).
I'll try hard to make it happen.
>Equus RIP
May it rest in peace... 😉
Bob
