file sharing
Hi All, I have used the file sharing a long time ago - i have saved the PLN as as a PLP but then what do i do ? MAke curser around the area i want then ????
3 Replies 3
You seem to be referring to TeamWork, since you are talking about a PLP (which is not created by a save-as). Have you considered reading the TeamWork chapter of the manual??
Karl thanks for that - we are reading the team work - cannot seem to save a PLC after saving as a PLP
Any top tips ??
pln -> share project -> .plp -> sign in (teamleader/mate whatever) -> save as draft= plc
hth
