help
i not use beacose in keyboard shortcast not sse tis command
9 REPLIES 9
Dwight
That's the first thing Graphisoft disables in a pirated copy.
Dwight Atkinson
Seriously Dwight? How do they do it? An internet worm that looks for dongles?
Dwight
Just joking. How would I know that?
Dwight Atkinson
Dwight
How possible is it that this has reverted to some bizarre demo mode?
Dwight Atkinson
Hi, Aleks!
When you start ArchiCAD your keyboard layout should be in English - then you will have Ctrl+V. When you start it in Cyrillic layout these commands just disappear.
thanks, but in my keyboard layout all time inglish
i try but nothing
help
Probably the problem is in the application for keyboard language change you use. Try uninstalling this application and restarting Windows and ArchiCAD.
If this doesn't help I suppose the problem is in the "russifficator" you use.
Write to me in ICQ - you have it 😉
i use patch build 2284 rus
i have 7 PC 5 pc all command work
in 2 PC not work
kliment you best!!!!!!!!!!!!
i not undestend that you say now try all ok
work
