how do i precisely input 3d cut plane values?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-09-07 08:49 PM
in v15, this doesn't work... so how do I do it?
Thanks!
Bill
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-07 10:23 PM
Bill wrote:Can you not enter values in the x/y/z boxes at the bottom right of the dialog, or am I not understanding what you're trying to do? You press the letter button (x/y/z) to lock the entered value(s). Or, as with the (somewhat deprecated) coordinates palette, press alt-x, alt-y, or alt-z to lock.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-07 10:41 PM
I've tried lots of different sequences but nothing seems to work. It's frustrating because for certain renderings I need the cut plane to be at a specific elevation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-07 11:47 PM
Bill wrote:
Nope, if I type in 'Z' I used to then be able to .....
Actually press the 'Z' button next to the value box - not the Z on your keyboard.
The process -
- Press 'Z' button,
- type in the height into the value box,
- move cursor to one of the side views and click once, you will find cursor is restrained to that height,
- click to one side of first click to confirm a horizontal cut,
- click above or below to select side to be hidden.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-08 03:07 AM
Bill wrote:It's working for me. Could it be a WE setting?
Nope, if I type in 'Z' I used to then be able to type in a new z-value.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-08 02:32 PM
Matthew wrote:WE > User Preference Schemes > Dialog Boxes and Palettes > Dialog Box Auto-Update Delay, but that would affect all dialog box input. Works as expected here also.Bill wrote:It's working for me. Could it be a WE setting?
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-08 11:16 PM
Thanks!
Bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-09 02:37 PM
You might want to check that the "z" key is used for accessing the "z" value in your Work Environment > Shortcut Schemes > Keyboard Shortcuts > Application Commands (List: All Command by Theme) > 13 Numeric Input > Z Coordinate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-09 05:21 PM
Bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-10 03:08 PM
Those are correct, so should work. Does the "z" key work for the Coordinates palette and/or Tracker?
