how to mouldings
im a newbie in AC , could somebody tell me how to the mouldings. i can only place it in horizontally.
how to change the inclination. the country whre i came from uses roof gutters in the form of of mouldings. my problem is how to have it so design attached in all the roofing edges. especially in the diagonal portions.
thanks
David Maudlin
dondi823:
Assuming you are using ArchiCAD 10 or 11 (you should add a signature with ArchiCAD version and platform), you can create a Complex Profile with the Profile Manager and make it accessible with the Beam Tool, then assign this profile to a beam, which can be given a vertical angle. You can search the Help files and this forum for detailed information about these features.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
