how to remove part of wall in 3d
Hi I have question how i can remove(subtract) part of wall as the one in elevation can i do it in elevation mode and results do the same in 3d
second, what is the best way to do it accurately to match the elevation drawing
Please help
6 Replies 6
Dwight
Use a round window opening.
Dwight Atkinson
no i do not want to make opening i want to remove the part of the wall to be curved in the end like the one in the image shaded with green
Dwight
Right. Put the opening on the corner. Easiest solution.
Another way is to use Solid Element Operation with a cylinder or other object as the Operator.
OR, set up a custom profile beam in a wireframe layer to intersect with the wall. By adjusting layer and wall priorities, the beam will cut the wall.
Dwight Atkinson
yes i will try the first and second solution but actually because i am not very advanced user i can not understand third solution(profile beam) ,by the way thank you very much for quick response
Rod Jurich
See attached, this is just one solution.
Edit:
Quick as ever, Dwight has another solution
And a suggestion you also learn to use a background colour other than black.
Rod Jurich
Thanks Rod Jurich for your clarification about black background i think i like it in 2d environment only because i get to use it in autocad 2d environment before so that is the reason but in 3d it does not matter.
