SOLVED!
how to select elements from toolbox/design
Hello, in the tutorial, beams and roof can be selected from the toolbox. But I cannot do that (AC 23)
Please advice how to make it
Thanks
1 ACCEPTED SOLUTION
Solution
Select (activate) the tool and then press CTRL+A.
That will select all of that tools elements in the view.
You can place a marquee around an area and then activate tool and press CTRL+A, and that will select all of that tools elements but only inside the marquee.
If you have the tool active and hold SHIFT while you select, you can manually add elements to your selection.
If to elements occupy the same space or nodes or edges, it will select the element that matches the tool you have active first.
You can still add other elements by SHIFT click, but you need to select away from the overlapping elements (or activate a different tool to suit what you are after).
2 REPLIES 2
Solution
great, thanks Barry.
