Archicad Help link opens wrong page
When I click the Help > Archicad Help menu command, it does not open the Archicad Help page of Help Center. Instead, it opens the following web page (Getting Started with BIMcloud Team Client 24):
https://help.graphisoft.com/AC/24/INT/BTCGS.pdf
Anyone else having this issue?
6 Replies 6
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Laci,
Thanks for the question! I noticed that a few days ago as well. Thought it was normal...
With the small number of AC24 versions installed on my computer, every language version works well except INT. Seems like only AC24 INT is affected by this. Does anyone with a localized version have this issue as well?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Noemi Balogh
Dear All,
There is an ongoing issue with our redirect service, therefore it can happen that the wrong link opens if you click on Help from Archicad or BIMcloud.
We are aware of this issue and we try to fix it on our end as soon as possible.
Thank you for your understanding and sorry for all the inconveniences it may causes to you.
Kind regards,
Noémi Balogh
Staff Community Expert, Admin
Miha_M
My INT version opens this, which seems to be the correct Help website:
https://helpcenter.graphisoft.com/?platform=win&release=0&version=24&utm_content=win-3008&build=3008&utm_medium=contextual-help&utm_source=archicad-24&utm_campaign=INT-FULL&lang=INT&type=FULL
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Miha_M
I noticed another Issue though. I haven't been prompted for an Archicad update for a while, so I used the Check for Updates menu link, which ported my Edge Chromium to a wrong location:
https://update.graphisoft.com/support/archicad/downloads/revitinout.html?gstype=support&gssubtype=revitinout&gslang=INT&gsversion=24&lang=INT&version=24&build=100&platform=Win64&auto=0&gsdummy=5
| Archicad 4.5 - 29
Interestingly, my Archicad version now correctly opens the Archicad Help Center page for Archicad 24. The Check for Updates link also takes me to the correct web page.
Miha_M
The Check for Updates link works here as well, but it opens up two web-browser (Edge Chromium) tabs. The first one http://www.graphisoft.com/support/archicad/downloads/update.html?gstype=support&gssubtype=archicad&gslang=INT&gsversion=24&_submitted=1&version=24&lang=INT&build=4000&platform=Win64&type=FULL&mode=FULL&install=853C5773-F32C-C725-3CF3-3578533FC352&acid=122978816&library=1590569172&libid=388016191&libbuild=30000006&auto=0&package=0&frequency=7&WKSN=2-2939396&WKT=Single&KEYTYPE=CM&gsdummy=5 doesn't display as it should, it has some basic HTML website content. The second one https://update.graphisoft.com/support/archicad/downloads/revitinout.html?gstype=support&gssubtype=revitinout&gslang=INT&gsversion=24&lang=INT&version=24&build=100&platform=Win64&auto=0&gsdummy=5 is displayed as it should. I probably got both of those opened with my previous post here, but didn't see the first one.
I don't have a second web browser installed to check how it works elsewhere.
| Archicad 4.5 - 29
