soldaotop
in 3d view all disappears when show all layers icon is clicked
normal 3d view
the same 3d view after I click on "Show all layers"
it seems that all the elements are here, but they just don't show properly because i can select them but they are totally transparent / white (?)
4 Replies 4
cuba
Could it be that you’re looking at a white volume that was on a hidden layer?
Apple M1 Max 32 GB
Latest AC
soldaotop
No, because the same thing happens from any other view onto the model (aerial view as well)
nothing can be seen but tihs x/y/z icon
But then i can select the model - it is here
Try turning on just a few layers at a time, until you come across the one that causes the problem.
Then look in that layer only to see what is there.
Charlie64
I had similar problems, although it happened when I went from 2D to 3D every time. I assume it was because my model had irregular walls and therefore it was very complex. My "solution" was working in axonometric view. I don't know why or how, but perspective was all white, like yours, but axonometric view worked fine.
I know this isn't the solution but hope it helped.
