join lines in elevations and 3d
I have a standard corner 90 degree wall to which I want white walls to the inside and coloured to the other. On one side of the wall I am adding a wall projecting to meet the eaves of the roof over. this wall I am making coloured on all sides as its outside.
How can I acheive the same thing without seeing the joint line in both elevation and 3d views.
Thanks
Todd
1 REPLY 1
If I understand what you are trying to do correctly,
Try going into your "wall selection settings" of the wall intersecting perpendicular and changing the "wall priority" by dragging the slider either way so it is a different value. This should clean up that line.
Hope that makes sense.
