KeesW
joining ceilings and bulkheads
I've created a composite comprising 10mm plasterboard and 90mm insulation which I want to use for both wall and ceiling to create ceiling bulkheads. How do I get these materials to join properly in cross-sections? I've create priorities 6 and 2 for plasterboard and insulations respectively.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
4 Replies 4
It is impossible. The only way is using each skin separately, not as composite.
KeesW
That is disappointing. This is despite the fact that composites have been created to be used as 'slabs' and 'walls' - but they still won't join. Should this be a wishlist item?
Rod Jurich
.................. well with SEO you almost get a perfect result.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Rod to me that is the perfect result as that is how the gypsum wallboard ( plasterboard ) would be applied.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
