label tool is not working
When I try to do a label with a tag ( a square or circle with id text inside)
The tool does not draw the arrow line (leader) nor the pointer. It only draws the tag. But if I label with text it draws everything: the arrow line and the text. I wonder what Im doing wrong.
archicad 8.1 win xp
I think this is a bug. The workaround I have found is to start the label with text and after it is drawn, change it to another label. Then it would be drawn correctly.
I realize that this thread is 4 years old (!) ... I came across it because I ran into the same situation of not getting a leader for symbolic independent labels.
GS support kindly pointed me to the checkbox shown in the attached screenshot, which I had long forgotten existed. If there is no check for 'Use symbol arrow', then the Label Tool will draw the leader. If it is checked, then there will only be a leader/arrow if one is scripted as part of the selected library part.
Getting old,
AC 28 USA and earlier   â€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
