line types on screen
is there a way to see all the line work on the screen as hairline instead of there set weights.. just to make trace referencing a bit easier. then switch back to the normal line weights?
5 REPLIES 5
There is a "True Line Weight" toggle in the "On Screen Display Options" in the "View" menu.
sweet.. thats so much better to work with
thanks
GeNOS, have you been drawing in crayon mode all this time? You must be very capable!
yup seems as tho i have been
I generally prefer to work in True Lineweight. Then you know what you're getting.
