maintaining origin point between plan & details
cremsberg
When I create a detail drawing from an area of the floor plan, the detail seems to create an origin point of its own that is not consistent with the X-Y-Z origin of the floor plan or model. This makes it more difficult to cut and paste between plan or section and detail. Is there a control for this that I am overlooking? Oddly, I can cut FROM detail and paste TO floor plan with successful location, but not the other way around.
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
6 REPLIES 6
Link
Yes - it's the node in the center of the detail bubble. Use the 'Move sub-element' edit in the pet palette to relocate it over your project origin, rebuild the detail from the source view (context menu in the detail window) and everything should copy & paste just fine.
Link.
Link
I should also point out that when you place a drawing of the detail on a layout, you should not set the anchor to 'Use Drawing's internal origin as anchor'. Set the anchor to the center of the drawing instead - this will prevent your detail jumping all over the page if you move over the model.
And if you do move it over the model, you will need to manually relocate the detail's origin again, and rebuild it from the source view.
Link.
cremsberg
Link – your suggestion of moving the center node of detail bubble to the origin point seems to move the entire bubble (Detail Marker Polygon) as if the detail is of something around the origin point. I’ve tried this while in either detail tool or arrow tool and it still doesn’t work like I think you intend. Thanks, though.
Claire Remsberg
cremsberg
Link – your suggestion of moving the center node to the origin point seems to move the entire bubble (Detail Marker Polygon) as if the detail is of something around the origin point. I’ve tried this while in either detail tool or arrow tool.
Claire Remsberg
Link
It won't do that if you select the 'Move sub-element' in the pet palette. That's the one in the top row.
Link.
cremsberg
Link – Honest, it isn’t working for me. I know which command in the Pet Palette you speak of. I am on ACv10 for Mac, and using Standard Detail Marker SE9, if that makes any difference. Thanks for trying!
Claire Remsberg
