Find and Select
I recently upgraded my Mac to an Intel based Mac. I had a Work Environment set up on my old system and I imported it into my new AC10 Intel version of ArchiCAD. When I laynched a drawing I found that Find & Select was missing from my settings. In fact it doesn't even show up in the Menu.
Can anyone help me with this? I like my personal Work Environment I have been using it for a long time and I don't want to use another one. In fact it seems as though Find & Select is not available even in the factory Work Environment settings, but I need to root around and check that further.
2 REPLIES 2
Find & Select is under the Edit menu in the standard WE (command+F shortcut). I have no idea what happened to your set up. I have had no problems.
Matthew, Thanks for the response. I have tried accessing it in the Edit Menu and the keystroke. Neither work. If you have any ideas in the future I would love to know. It was working in AC10 on my PowerBook but not on my MacBook. Frustrating.
Matthew Beardsley
