material window
ratnabhirud
Hello,
I have set my AC 14 template in which, I have deleted all Cadimage materials because I don't want extra material list.
But when I open new customized template, Cadimge materials appears again.
Am I going wrong somewhere?
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
2 REPLIES 2
No you are not doing anything wrong.
You will find these materials are loaded from a GDL file in your library.
This file will start with the name - MASTER_GDL_........
I can't tell you exactly what the name will be as I don't have the Cadimage add-ons loaded.
So all the time you have this in your library they will be added to your attributes every time the library is re-loaded.
i.e you can delete them but they will come back.
You will notice in the attribute manager that thier names are in itallic text.
The same can be done for line types and fills.
PS
If you delete the file from your library then your Cadimage objects will have missing materials.
