measurements
hi everyone,
i have problem with measurments, when i measure an object the result is ???? (question marks and not numbers!!) strange, isn't it?
I changed the units from meters to centimeters and i played with the units settings, but it is not working!!!
any ideas?
4 Replies 4
Can you show the problem on a screenshot?
abulol wrote:
hi everyone,
any ideas?
mostly its the regional settings for windows ... if the numbers are "hindi"-by mistake referred to as "arabic" ..this might happen . I've seen it before if I remember well ... if you are on Mac .. try to put English as first language ... if you are on windows try to set the country to another .
This article on the ArchiCAD Wiki may be relevant -
http://www.archicadwiki.com/Bugs/Cyrillic%20font%20problems?highlight=%28language%29
Hope it helps.
thank you for your reply
am using mac not windows..
and it works by changing the first language
in the system preferences the Arabic was the first language,
i change it to English..
