mesh tool?
Hi. What can I do to make the rough terrain smoother? In this picture you can see some edges in this little hillside... Is it the mesh tool that is the right tool to use for drawing the terrain?
ruttis
It looks like you have points at various elevations creating the jagged look. It is best to draw contours on the mesh (you can also magic wand to splines or polylines) and adjust them to the right heights. Do this in plan (click a node on the contour and the icon on the pet palette for adjusting the height) and make sure to check "Apply to All" in the dialog. (In 3D you can only adjust the heights of individual nodes)
You can also smooth the edges by "all ridges smooth' in the mesh dialogue/model.
