mirror and rotating an object on a different axis
Hi! I seem to be having difficulty mirroring and rotating an object on a different axis. Can anyone help?!
Srinivas
I believe you want to rotate the object about Z axis, if the object hasn't got a parameter in its properties to rotate, you can always use this free library part rotator.gsm
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/Archicad%20Modules
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Ralph Wessel
Take a look at OBJECTiVE. You can, for example, rotate objects in elevation just as you would in plan. A tool like this is essential if you are trying to rotate multiple objects about a common point. You can find an example here, and there are many more if you do a search.
Ralph Wessel BArch
Central Innovation
