missing find and select palette
I cant seem to make the 'find & select' palette appear either by shortcut or via edit menu. Anyone else experienced a similar problem?
Any help appreciated.
Have you changed screen resolution or size since you last used it? It pops up wherever it was last located, so if your screen size changes it may have fallen off the edge of what is now visible. Just a guess. (Not sure how dual screens might effect things)
Couldnt get it back by changing resoltions but I opened up a new file with standard profile work environment and no problems ....... closed that, reopened existing file and bingo its back!
Thanks
Aaron Bourgoin
Hi Adam,
You can 'reset'the work environment without closing your file. Just apply the standard profile from the Work Environent menu (below 'Preferences') and it should come back or let you turn it back on.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
