We value your input!
modelling in archicad
keily
hey everyone! im wanting to make an earthquake looking crack in archicad, any suggestions or thoughts on how to do this
thanks a bunch :))
Use a slab or morph drawn with the polygon method and then use solid element operations to subtract the ‘crack’ from the surface. Make sure the original surface and the crack are on different layers.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
DGSketcher
Legend
You could also use the OPENING TOOL, but it depends on the receiving Element type if you can apply it.
