pdf on worksheet is out of scale, skewed
Have a pdf floor plan that is too narrow if the length is correct and too short if the width is correct. Do we have the ability to skew pdf's some way?
9 Replies 9
Use the Figure Tool instead of the Drawing Tool to place the PDF. See "Scaling" here:
http://www.archicadwiki.com/DifferenceBetweenDrawingAndFigureTools
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Steve Jepson
Did you try using stretch (Ctrl-H) rather than resize (Ctrl-K) ?
When you select a Figure there will be a a place to tweak the dimensions in the Info Box. You may need to click on the little chain links if you want to change height and width independently.
Hi Karl,
Been trying that since I read that article, but putting .pdfs with multiple pages and no images inside have been unsuccessful.
I first placed the figure tool and then opened to locate the PDF the dimensions of the page does not come up. See attached image.
Thanks.
The figure tool can't place PDF files on Windows machines - only works on Macs.
awwwww.
You can't place PDF's but you can export to image from the PDF into something usable like TIFF, PNG, or JPEG. Well, I suppose that depends on your PDF reader but I this all the time.
Actually, went and measured the interior of the building to create accurate "as-builts", verify the floor elevations, stairs, windows, etc. Took a lot of pictures and found another problem.
Our stairmaker will not let us use it to show old fire escapes in the "up" position, only down. Does anyone know how to show a fire escape "up"?
ratnabhirud
Hello Archimamamia,
Here is the answer for your question.
Go to File - External content - place external drawing,
Then check proper file type i.e. pdf and select - place wherever you want.
You may place it on Plan or on Layout.
It works on both Windows and Mac.
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
ratnabhirud wrote:
Hello Archimamamia,
No - The original poster wanted to distort a PDF. As discussed earlier on in the thread, this can only be done using the figure tool on a mac. You don't have the option to do this on PC.
