pla file is better than pln file???
what do you usually save your archicad file as? pla? pln? which is better? why?
One is not so much better than the other - they each have entirely different purposes.
A PLA archive is to include all related library parts and textures (etc) in a single file for moving to another machine or for archiving at the end of a project. It will be very much larger than a PLN, which should be the workaday file format - unless you have reasons to use TeamWork.
Karl
Karl
thanks!! karl
