please help me """BEAM Designing""""
I plan to daw a Beam for my building!!!!
the Beam I want to draw should have a thick end and a narrow end
at the other side!!!!!
my Question is with which option in Archicad I can do that????
please help me
thanks in advance!!!!!
5 Replies 5
Try using the wall tool. Use the Trapezoid wall.
See attached pic.
See attached pic.
thanks in advance, but I mean the height of that Beam but the way you mention above is changing my Beam`s width!!!!!
please look at these two pictures
the first is original one but the second is the way I want to change my Beam!!!!!
Iwish you can help me over that!!!!
thanks again
Oh ok, no problem all you have to do is design your beam using the complex profile tool, and within the tool indicate that you want to use it as a beam. Then in the beam tool simply select the complex profile.
see screen shot attached.
See pic on how to use the profile you designed.
I do not know how to thank you!!!!!
your help was great and my problem solved!!!!!
thank you again!!!!
