Learn more
plotting drawings
I have moved from AC 9 to 13 and see that Plotmaker is no longer used, I understand that the plotting is now direct via AC. Is there an on-line tutorial I can follow that will show me, step by step, how to create files for plotting and to subsequently plot them?
Any help would be appreciated.
1 Reply 1
One quick way of learning, with a familiar AC 9 file, is to just migrate that file to 13. In your Reference Guide, see the chapter called "Migration Guide for ArchiCAD 13".
Otherwise, in the Reference Guide PDF, read the Chapter called "Documentation", particularly the subchapter "The Layout Book".
