porch query
I am working on a small residential project which includes modelling an existing house.
Attached is a photo showing the entrance feature.
Forming the arched opening is ok using the empty door option but I am unsure how to create the moulding feature at the top of the arch.
Could anyone shed some light on how best to achieve this?
Thanks
Rod Jurich
As a student you could not do better than OBJECTiVE
It is free to students, check the videos. Highly recommend.
You would do others a service to tell us your version of AC and what OS you use.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
David Maudlin
j12ebr:
This could be made with slabs then saved as... a custom object, in the Help files see Virtual Building > Parametric Objects > Graphic Creation of Custom Objects.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David and Rod
Signature should be added now....!!!
