problem vith corner window function in AC16
Hello!
I use variable window 16.
When I turn on custom corner option with connection type to be glass, the glass goes out of the window frame.
This was working just fine in AC15 so it is a AC16 problem.
Can this be solved?
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
it seems that some parameters are not proper in this window.
To investigate this issue, please forward the .pla project to your local distributor (http://www.graphisoft.com/purchase/europe/croatia.html) or attach it here.
Best regards,
Katalin Takacs
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Please try to place these windows with the "Corner-Window Tool".
The problem may occur in simple variable windows that are set to corner window type only.
Katalin Takacs
