program defaults
Hi all,
is there a way to revert to the program settings defaults? I'm trying to draw lines but zero is never at the point I click but the default 0,0 point. This is truly bizarre, as I never fiddle with the settings, and up to my last session this wasn't an issue.
Thank you
Not sure if this is what your after, but;
There is the the "New & Reset All" option.
Zoltar,
If you use the "tracker" when drawing then there is an option in the tracker settings to use "Relative co-ordinates in tracker".
If you don't use the tracker and instead use the co-ordinate palette then make sure the triangle (delta) buttons are pussed in (next to where you input the co-ordinates in the palette).
Thanks Barry,
resolved the problem. It was driving me round the bend.
